Categories
G-Wizard Calculator:
Fast, Easy, Reliable Feeds and Speeds
Subscribe
Join 50,000+ CNC'ers!  Get our latest blog posts delivered straight to your email inbox once a week for free. Plus, we’ll give you access to some great CNC reference materials including:
GCode is Complicated
G-Wizard Makes it Easy
CNC Question Exchange
0 votes
  Hi there! I hope I make sense, Im very new to cnc machining so please bear with me… ...
  • ulf höglund asked 10 months ago
  • last active 10 months ago
0 votes
I have one of Aaron’s first IH mills. What have you done to yours, if you still use it, to ...
  • Paul Spurgas asked 10 months ago
0 votes
hi, i am slitting a 2″od (50mm) x 1″ id (25mm) x 1/2″ thick (12mm) – mate...
  • deon asked 10 months ago
0 votes
Hello, Can this software help me create a Custom Post Processor for a Mill ? I don’t need a...
  • wozDaddy asked 10 months ago
0 votes
How do I enter an “overall (tool) length” in the geometry section of my tool crib?  T...
  • Edward Kleinman asked 11 months ago
  • last active 11 months ago
0 votes
what is first to setup, do i have to setup it with  my machine pc or can i use it on a pc desktop...
  • Miguel Sendejas asked 11 months ago
0 votes
Hi Bob, I know that power and torque are mathematically related.  You talk about the power of spi...
  • David asked 11 months ago
0 votes
Is there a way to turn off the image of the tool in the visual simulator in GWizard?
  • Cary Brace asked 11 months ago
0 votes
Looking for feeds and speeds for milling Crucible CPM 3V steel in the annealed condition.  It is ...
  • Doug Peariso asked 11 months ago
0 votes
Hi, I have an A2Z mini-mill, with an 0.8KW motor. Previously, I used the weight-adjusted profile ...
  • Lukas asked 11 months ago
0 votes
how to execute new graph in fanuc alpha oc 16 w? anyone can help?
  • piyush dhokiya asked 11 months ago
0 votes
I have years of CNC programming expearace in G-Code from factory work, and I have an old H-Square...
  • Jack Barnett asked 11 months ago
0 votes
I currenly have a small CNC (Proxxon MF 70 CNC-Ready) which has a 100W spindle. So a 1 year subsc...
  • Marek asked 11 months ago
0 votes
I tried to cut a small opening in ABS box and I got these values from GWizard:   The cut de...
0 votes
I am brand new to CNC.   I am getting ready to purchase my first machine https://stepcraft.us/   ...
  • Jeffrey Kay asked 11 months ago
0 votes
Hi All, I want to cut a 50mm diameter cylinder out of a block of 6061 aluminium that is 40mm thic...
  • Gary Williams asked 11 months ago
0 votes
1k views
Hi Im just getting started and got my mill up and running this weekend. Its a Skyfire CNC (the sm...
  • Leo Sandström asked 11 months ago
0 votes
I make engraved signs on my Chinese CNC machine.. after setting it to ZERO position, now after ev...
  • Rob Weaver asked 12 months ago
0 votes
Hello, I am in the process of setting up the tool library.  Why is it that every tool after the f...
  • Tim asked 12 months ago
0 votes
What is the recommended foot pounds of torque to securely tighten a double kurt vise?
  • Josh asked 12 months ago
  • last active 12 months ago
Showing 21 - 40 of 239 results
Do you want to be a better CNC'er?
Get Better Tool Life, Surface Finish, and Material Removal Rates.
Start Now, It's Free!
Home
Software
  GW Calculator
  GW Editor
  Gearotic
  Conversational
  Deals and Steals
CNC Blog
  Software
  Techniques
  Beginner
  Cool
  Projects
Cookbooks
     Feeds and Speeds
     G-Code Tutorial
     CNC Machining & Manufacturing
     DIY CNC Cookbook
     CNC Dictionary
CNC Projects
Resources
     Machinist's Search
     Videos
     Online Groups
     Individuals
     Reference Data
     Books
     CNC Dictionary
     Suppliers
     Tool Brands
Workshop
     Hall of Fame
     Organization: Soon!
About
     Customers
     Partners
     Our History
     Privacy Policy
All material © 2016, CNCCookbook, Inc.
