Parabolic vs Standard Flute Twist Drills = Better Performance
May 2, 2017   //   by Bob Warfield   //   Blog, FeedsSpeeds, Techniques  //  11 Comments
What Is a Parabolic Flute Drill?
The term “Parabolic Flute” applies to a specific geometry for a twist drill.  The geometry is altered to improve chip extraction, which leads to all sorts of advantages for Parabolic Drills:
  • Reduces the need for a peck cycle except on deepest holes.
  • Allows increased feed rates for better manufacturing productivity and shorter cycle times.
  • Improved chip evacuation leads to a better surface finish in the hole.
If we look carefully at the two twist drill geometries, we can see how recognizable parabolic drills are:
ParabolicVsStdFluteDrills2
An end-on comparison is even more telling:
ParabolicFluteShapeFlute shape of a parabolic vs standard geometry…
The name comes from the flat parabolic shape of the flute.  You can see from the diagram what all has been done to get the twist drill out of the way of the chips as much as possible.  This allows higher feedrates even for relatively short parabolics and I have heard from some machinists who use parabolics exclusively for that reason.  Kimball, another parabolic supplier, recommends avoiding parabolics for sheet metal because the flute shape can cause them to “corkscrew” through the material.
I think it’s also fair to say that parabolic drills are more premium (expensive) products, so most manufacturer’s are taking more care with them in general.  They’re just higher quality cutters.
When Do I Need to Use a Parabolic Flute Drill?
If you’ve ever used G-Wizard Calculator to try to figure feeds and speeds for deeper holes, you may have noticed it recommending a “Parabolic”:
parabolic flute hole depth
G-Wizard thinks you’ll have problems with this hole if you don’t use a Parabolic Flute drill…
As a matter of fact, GW Calculator will tell you quite a few interesting things to improve your twist drilling including when you need to use a Peck cycle (where the twist drill is retracted periodically as it moves down the hole to break chips) and what point angle will work best with your chosen material.
Once G-Wizard gives you a warning, it means you’re likely to have problems if you try to drill the hole without the requested drill geometry.  Geometry is they key word in this case, and you can get G-Wizard to calm down and give you some feeds and speeds by popping open the Geometry window and selecting Parabolic flutes.
So what are the governing these recommendations?
G-Wizard uses the following rules when making depth-based suggestions about holes:
–  At 4x diameter, it will start asking you to peck drill.
–  At 8x diameter, it will ask for parabolic flutes
–  At 20x diameter, it’s become a black art.  Time for some sort of custom Deep Hole Cycle g-code programming and maybe a call to your tooling dealer for something that’s probably either very expensive or very slow.
As you can see, there’s some complexity involved with any hole more than a few diameters deep.  The reason the Parabolic Flute Drill can help is its unique flute design.  Here we can compare standard versus parabolic flutes side by side:
The big deal on the parabolics is the faster spiral.  I’ve marked the same number of turns in the diagram, and we can see that for a given number of turns, the parabolic will have moved the chips further up the helix due to its faster spiral.  Parabolic drills often have other geometry advantages including more room in the flute for more chips and a wider web on the tip for greater durability.
Parabolics are quite a bit more expensive than the average jobber length twist drills, but for deep holes, they’re darned well worth it.  They may even be worth it in shallower depths just because of the increased feedrates they can bring.
Here are the G-Wizard feeds and speeds for a 1/2″ twist drill going 2″ deep in 6061 aluminum:
twist drill aluminum 6061 feeds and speeds
Regular Twist Drill feeds and speeds…
The Material Removal Rate is 2.57 cubic inches per minute.  Now, let’s try that same hole with a Parabolic Drill.  To change, click the Geometry button:
Just select “Parabolic” Tip Shape from the Geometry menu…
Here are the feeds and speeds with Parabolic:
The MRR goes from 2.57 to 3.00 cubic inches per minute with a Parabolic drill…
The MRR goes from 2.57 to 3.00 cubic inches per minute with a Parabolic drill.  That’s about 17% faster–worth it for many jobs!
If you haven’t tried our G-Wizard Feeds and Speeds calculator, get a free 30-day trial.  Not only does it make these useful recommendations such as when you need a parabolic drill, it does a whole lot more besides!
Check Out the G-Wizard Calculator
3.3 (66.67%) 3 votes
11 Comments
  • I try to run Parabolic whenever I can, no matter what material.
  • […] that gives the parabolic the advantage as the "grind" on the tip can be the same. Parabolic vs Standard Flute Twist Drills – CNCCookbook CNC Blog CNCCookbook CNC Blog Cheers, Rich __________________ Take everything I say with a grain of martensite Classic […]
  • If I was to use a parabolic drill, what info would I need to input for g wizard to give me speed n feed?
    • Just select “Parabolic” with the Geometry button.
  • are carbide drill and parabolic drill the same thing?
    • They’re different classifications: carbide is a material, parabolic is a shape.
  • I’ve been using a 3/8 parabolic to drill 2 inch holes as a material removal step before end milling. I start by drilling a pilot hole with, then peck drill to depth. Question though, when the 3/8 carbide drill initially breaks the surface (7075-T6) I get a hell of a squeaky racket, even with coolant. I following the speed/feed suggestion of 4500 rpm and both my CAM and Wizard are in agreement. Is there another step I should take between the initial hole starter and then pecking with the 3/8? Perhaps stepping up the holes with a smaller diameter drill?
    Thanks for the great tutorial,
    Dan
    • Is the tip angle on the drill > than the tip angle on the spotting drill? If so, it’s because the tip is not starting the cut because the angle is too wide, so the sides are engaging the edge of the hole made from the spotting drill. A lot of spotting drills are 90°, meaning you need a drill under 90° for the tip to actually start the cutting. You could try using a 120° spotting drill with a 118° drill. That will solve the squeaking problem.
  • Do you center drill/ spot drill before hand? If so, what’s the rule of thumb for the different sized drill bits used?
  • […] suitable for cutting light-gauge metals. The drill improves and speeds up chip ejection due to its parabolic flute design while […]
