Suppose you had to build a bunch of space frame tube chassis like this one:
GoblinFrame
Making a bunch of space frames means notching a lot of tubes…
Making all those space frames means notching a lot of tubing.  Sounds like a little CNC-style automation is in order.  That resulted in this CNC-driven plasma cutter tube notcher that I came across over on Reddit:
Frame2
Start by welding up a simple frame.  The plasma torch will ride along that rail…
iwgljkG
A simple chain drive pulls the torch sled up and down the rail…
EyS20X2
The sled itself is very simple and rides on ball bearings that engage the rail corners…
vBdeX0e
Another view of the sled showing the attachment to the chain…
zqc11CU
A pivoting bar will hold the torch.  It rides on the tubing (bottom) to be cut so torch height can be set…
foVpeD8
Torch is held to the bar with brackets…
0SEYCbk
The tubing sits on skate wheels (so it can rotate) on a parallel frame…
Fo3E8xZ
A Chevy Cobalt wheel hub is the perfect base for the 4th axis…
2AVXNtD
Add a 3-jaw chuck from a weld positioner to hold the tubing…
xuFfHc8
Stepper motor for the chain axis is also chain driven…
JVLtTk2
With another chain-driven stepper motor for the rotary axis…
Gh2leFw
Throw on a little paint to make it pretty and you’ve got a CNC plasma tube notcher!
Mach3 is perfect to drive it.  The architecture is just 2 axes, but one is rotary so a lot can be done.  The tubing notches come out great.
Be sure to check out the DF Kit Car site that’s what all this is for:
Goblin
I bet these little Goblins are a real handful but a total blast to drive!
DIY Plasma Tube Notcher
5 (100%) 1 vote
Pin It on Pinterest
Share This
