One of the problems with getting started with a DIY CNC Conversion is not having a CNC to help you make the parts. You can find kits, which are very helpful. You can try to manually machine the parts, which is entirely doable. I did some of both for my first CNC project–an RF-45 mill conversion. But I came across another approach that seemed to work extremely well–bootstrapping the project with a 3D printer.
Let’s say you’ve got a 3D Printer already, and you want to augment its capabilities with a CNC Mill. Presumably you’ve got plans for the CNC Conversion Kit for your Mill. Basically, you’ll need motor mounts and ballnut mounts for the ballscrews. Over on Reddit I came across a guy who used his Rostock-style 3D Printer to do just exactly what I’m describing. He started with a set of plans to convert a G0704 from Hossmachine (great site for DIY’ers, BTW!). Here are some pics showing the 3D Printing aspect below. More details on his photo blog of the project.
You didn’t provide any text. Please enter the text you’d like me to rephrase.
Here’s a shot of his Controller built in an ATX PC Case…
And here it is with wiring. The author talks about 3D printing some wiring conduit to help clean it up–another brilliant use for a 3D printer!
Motor mount from Hossmachine’s G0704 plans. This was scaled up to support NEMA 34 motors.
Here’s the 3D Printed Y-Axis motor mount. PETG was used for superior layer adhesion, strength, and hardness.
3D Printing the Y-axis Bearing Block…
3D Printed X-Axis Motor Mount…
Y-Block and Motor Mounted, Installed on Mill…
X-Axis Mount bolted up…
Lovejoy coupling up underneath mounts…
Z-Axis will look like this…
3D Printed Z-Axis Mount…
All axes are bolted up…
Initial cuts with a facemill. That’s roughing pass in the foreground showing via equal crosshatch patterns that the mill is trammed properly. The rear is a finish pass. Not too shabby for plastic parts, ACME screws, and plenty of backlash!
The point of all this is to machine these nifty new mounts out of metal for ballscrews…
Here’s what the new metal parts look like. They’re CNC machined and came out gorgeous.
Bootstrapping with a 3D Printer made this project come out really nice. If you don’t have a 3D Printer, you could still take this approach. Just use Shapeways or one of the other 3D Printing service bureaus to make your plastic parts.
Hi BOB
I like this out of the box thinking. My first foray into CNC was the building of my own 3D printer. I have published a lot of the parts I designed on Thingiverse under my alias ‘Endlesshunt’. I also have a ZX45 (near exact duplicate of the Grizzly G0761) that I got about 5 years ago. I’m now planning to convert it to CNC as well. In the articles that you wrote about your RF45 conversion, you referenced the IH web site often for how things like grinding the dovetails etc. was done. As that website no longer exist, is there another source for those how-to articles?
Are there any plans available for these (ZX45, G0761) machines? There are a lot of people that tell of their conversions on these machines but no concrete data as to the actual parts used (ballscrew dimensions, or drawings of the fittings manufactured etc.)
Regards
Deon
Hi BOB
Regards
Deon
This is very interesting i believe diy 3d printers are a really good way to learn about 3d printing. But i love this way of thinking i might try it maybe in the future. Thanks for the idea and really nice article.
Cheers!
