2 years by cncdivi
What is a Co-Ax Indicator?
It’s a common problem for a machinist to need to find the center of a circular feature–either a boss or a hole. There are a lot of ways to do this ranging from using a probe on a CNC to using one of the many tried-and-true methods that started out with manual machining. Our Complete Guide to Metrology goes over a bunch of methods.
The Blake Coaxial Indicator is one of those methods left over from the days of manual machining:
A Blake Coaxial Indicator…
You stick one of these little goodies in the machine spindle, position it over the feature in question, start it spinning slowly, and adjust position until the indicator needle stops swinging. There’s an offset arm not shown in the picture that keeps the indicator facing your way. It usually takes more time to dig out your Co-ax Indicator and stick it in the machine spindle than it does to dial in the feature–they’re very convenient, in other words. If there’s a knock on them at all, it’s about their accuracy.
Here is a video showing how to use your Blake co-ax indicator:
You can purchase a co-ax indicator off Amazon for prices ranging from about $109 for a knock-off to $439.99 for a “real” Blake Coaxial Indicator.
If you want to measure the feature much more accurately, most machinists reach for what is typically called a “Zero Set:”
Zero Set-Style Indicator Holder…
The one I’ve got was made for me by a fellow from CNCZone called “Widgitmaster.” It’s a beautifully made piece of work with a fine screw adjustment for diameter. You stick it in the machine spindle and you can tell when you’re centered on the feature because you rotate the DTI (Dial Test Indicator) and get no motion on the needle. With a nice Dial Test Indicator, you can measure very accurately indeed.
A coaxial indicator set should include:
- The spring loaded co-ax indicator.
- A set of probes that range from straight to curved.
- An offset arm to keep the co-ax indicator facing your way as the machine spindle rotates.
Since the co-axial indicator is a centering indicator, it is a relative reading tool, not absolute. Therefore, no calibration is needed when we switch one of the probes for another.
A couple of tips when using a co-ax indicator:
- Keep the machine spindle to slow rotations. If you start the machine up at over a few hundred rpm with a co-ax indicator in the machine spindle, things will get ugly in a hurry.
- Make sure the probe is contacting the bore (or boss) all the way around an entire rotation.
- Start out having “eye balled” the tool to the center of rotation.
If you’ve taken a few moments to ensure those areas are covered, your co-ax indicator is ready to find the center of the bore or boss very quickly.
How Accurate is a Blake Coaxial Indicator?
But just how bad is a Blake Indicator compared to a Zero Set Dial Test Indicator rig like this? I tend to reach for my Dial Test Indicator when I want to position to a thousandth of an inch or better and use the Blake when it is less critical. Most of the Blake’s error is due to what is called “cosine error.” It’s possible to have cosine error even with the Dial Test Indicator rig. It’s a function of the angle the measuring needle has:
Keep as small an angle as possible on your Dial Test Indicator to minimize cosine error…
The cosine error is determined by the angle of the indicator tip to the surface being swept. No angle or a very small angle means no error. A large angle means a large cosine error. How large can the error get? Well, we can just take the cosine of some angles to see. Let’s try this for some real measurements. Let’s say we want to measure a distance of 0.010″. If our indicator tip angle is 60 degrees, we multiply the distance read off the indicator (0.010″) by the cosine of the angle:
cos( 60 ) * 0.010 = 0.005″
What that means is that with the tip at a 60 degree angle, when the indicator reads 0.010″, the real distance is 0.005″. That’s quite a bit of difference! Clearly we want to be sensitive to cosine error when taking such measurements.
Aside from paying attention to the angle of your measuring probe, there are some interesting ways that DTI manufacturers have worked to minimize cosine error. To learn more, click that prior link.
Note that the Blake Coaxial Indicator is a relative measuring device, so the effect of the cosine error is largely to reduce its sensitivity. If you wonder exactly how much error we’re talking about here, we can use G-Wizard Calculator’s Geometry module to figure it out pretty easily. This kind of problem comes up fairly often, and it’s useful to be able to put real numbers to a solution. For example, it is a similar calculation to figure out how accurately a DRO scale must be aligned to a machine axis to give accurate measurements.
For this problem, let’s first consider the mechanism of the Co-Axial Indicator. It basically uses a probe that swings a little lever as the machine spindle rotates. That lever raises or lowers a ring, and the ring is connected to an indicator. The lever on mine is about 1/2″ long. So an important question to understand is how far must that lever move in order to move the indicator a particular distance, such as 0.001″?
Here is the geometry:
How far must the arm of a Co-ax Indicator move to make the indicator needle show 0.001″ difference?
Now let’s set up the calculation in G-Wizard that produced that 0.1146 degree figure:
The Right Triangle Calculator from the G-Wizard Geometry tab…
This is an easy problem to set up. Referring to our CAD drawing, distance “A” is the 0.001″ change on the indicator. Distance “B” is the offset of the probe tip.
Here is the result:
We use the Right Triangle Geometry Calculator to find the angle…
And sure enough we can see the angle is 0.1146 for that particular deflection.
Given that knowledge, its easy to use the same calculator to figure out for a given probe length, how much it deflects to generate the same angle (0.1146 degrees)?
Here is our result:
Co-Ax Indicator Reading | |||
Probe Length | 0.0010″ | 0.0005″ | 0.0001″ |
1″ | 0.0020 | 0.0010 | 0.0002 |
2 | 0.0040 | 0.0020 | 0.0004 |
3 | 0.0060 | 0.0030 | 0.0006 |
4 | 0.0080 | 0.0040 | 0.0008 |
5 | 0.0100 | 0.0050 | 0.0010 |
6 | 0.0120 | 0.0060 | 0.0012 |
Probe length on the left, indicator reading at top, boxes contain the level of cosine error…
We can see that the indicator’s accuracy is based on how well you can read the dial. As mentioned above, the Blake’s is calibrated to 0.0005″ increments. You can certainly see that much motion of the needle, in fact it looks huge. Can you see the wiggle of 1/5 of a division? I certainly can, which would get me to the 0.0001″ column. The longer the probe, the less accurate you will be, but I seldom use a probe longer than maybe 3″, so the accuracy of the indicator is not too bad. Looks like a little over half a thousandth with the long probe.
You’ll still do better with a Zero-Set and Dial Test Indicator, but if you can read your co-ax indicator well enough, they’re more accurate than many believe.
I’m actually using that identical indicator today, I even posted a pic of it on Instagram! lol
I’ve got a cheap SPI indicator, but I’m practically ballparking center while reworking 60 year old industrial water pump components. The 6″ probe that came with the indicator isn’t long enough for some of the work I do, so I made a 12″ probe. Any longer and I’d have to counterweight it!
I can see how the cosine error can raise problems if you are trying to measure the diameter of a feature.
But if you are trying to find the center of the feature, as long as the reading is the same all the way around then you’re at center regardless of the cosine error.
Mike, it’s basically what I said in the article–cosine error can reduce the sensitivity of the test by reducing the amount the needle swings. In an extreme case, it may reduce the swing so much that it is hard to see it move enough to center within the tolerance you desire.
I understand that, but the article is misleading. It is throwing coaxial indicators under the bus particularly by specifically naming Blake as being unreliable, while including one sentence in there that’s states “It’s possible to have cosine error even with the DTI rig”. The cosine error is a function of the angle of the probe not the coaxial indicator. My coaxial indicator came with straight probes as well as angled probes. I just feel that the article would be more informative if it would have focused on the angle of the probe being the problem instead of basically slandering coaxial indicators.
Mike, the articles winds up concluding coaxial indicators are fine. And it does consider the angle–cosine yields no value without an angle. That’s the whole point of the article. You do actually have to read it to reach a conclusion.
I stand by what’s written–it’s accurate and not particularly misleading at all.
I have been using a Blake for about 30 years and when I opened my shop I got another one incase something happened to mine. I originally got it because I worked on a lot of horizontals and it removed the drift issue and all the fussing to watch it with a mirror, I stated using it on all my setups. anyhow I use it all the time with the 1 in arm, some times with the arced arm but in either case it has never been a problem. I understand the sensitivity part but with the shorter arms its never been a issue. something that was not in the article, I run mine at 100 rpm every time I use it. I trust the Blake and parts have been inspected to be within .0002. Note also, I tried the other knock of Blakes, the blue ones but they simply are not as good as a Blake.
thanks for the article.
I have the Blake Indicator as well. This kind of information is very informative.. Thanks for publishing this article.
I always wanted a Blake indicator but always just chucked the DTI up instead.
How well do the cameras that integrate into CNC controller software work for finding centers and indexing?
My Blakes worked pretty good until my operator typed 8000 instead of 800 and started the spindle. When I heard it from the programming room I was knew exactly what had happened. Anyways, I then bought a cheap chinese one for him to use that cost half the Blakes but the bottom plate wasnt square to the spindle shank so it was always off to the left when the dial was facing forwards. The longer the tip you put in the worse the error. Something to beware of when buying cheap sh*t.
Blake indicators do not really have a calibrated division. They only are calibrated to 0.0005 divisions when working with a bore diameter of 2″ using the 2″ feeler. Measuring any other bore diameter with any other (appropriate) feeler makes the divisions change accordingly. Therefore, wouldn’t your ability to correct for the cosine error need to take the effective sensitivity of the indicator into account?
You’re correct, but as I say, the Blake is a relative tool and the effect of the cosine error is to reduce its sensitivity. All we’re really trying to do here is to estimate the effect of that reduction. You’d have to redo the calculation based on your actual geometry and equate that to your indicator to see if it mattered.
Understanding the question and the problem is often more important than the answer.
