3D Printing for RC Plane Modelers and Drone Builders
Dec 2, 2014   //   by Bob Warfield   //   3D Printing, Blog, CNC Projects, Cool  //  6 Comments
I was an avid model builder in my youth, and carried it forward into adulthood when I was much younger by building RC (Radio Controlled) Planes.  My biggest problem was that the planes took a long time to build relative to the length of time I could fly one before crashing it.  I think I eventually got to a 4 or 5 to 1 ratio, meaning I could successfully fly the plane for about 5 times more hours than it took me to build it.  Not all of that was a function of improving my piloting skills though–I learned how to build those planes much more quickly over time.  Looking at what’s possible today, I can see that times have really changed–it’s almost enough to make me think of taking it up again.  Almost.
The advent of hobby class 3D printers has put a whole new tool into the hands of RC Modelers and Drone Builders that has some serious advantages over the old days of buying a balsa wood kit at the hobby shop.  You’ve got an unprecedented ability to create one off models or to add 3D printed parts to an existing model to make it a better or more unique scale model.  The details that go into making a scale model really beautiful were always scarce in those balsa kits.  The best modelers had to fabricate all sorts of parts to add those details to their planes.  A 3D Printer is an ideal tool for doing that.  In addition to scale details, there’s a wealth of other parts that go into the plane–servo trays used to bolt your servos and RC electronics down, linkages to transmit power from a servo to a control surface or engine throttle, and so on.
Here’s a scrapbook showing some of the many amazing things talented modellers have accomplished for their RC Aircraft and Drone projects using 3D Printing:
TrainerDrone
An R/C Trainer by the same University of Virginia team that did the 100 MPH drone below…
3dood-feat
Old School flyer was made entirely with a 3DDoodler 3D Printing pen!
OpenSwift
OpenSwift is an open source R/C Flying wing that combines 3D printing with conventional construction to produce a lighter model…
P38
5 Foot Wingspan P-38 is a Monster…
3dprintedSpinner
There’s no end of parts like this 3D printed prop spinner needed to build a Scale R/C Plane…
Pilot
The detail on this 3D printed pilot is better than anything I ever saw come out of an R/C Kit.  It was 3D printed by Shapeways on their high quality industrial 3D printers–just a reminder that you don’t even need to own a 3D printer to benefit…
A complete 100 MPH 3D Printed drone from the University of Virginia…
CarbonMold
Want super-strong and light carbon fiber for your project?  No problem.  Use the 3D Printer to create the molds.  Be sure to check out our CNCCookbook series on carbon fiber molding while you’re at it…
3D-printed-mini-jet-engine-from-GE
For the ultimate R/C project, how about 3D printing a real miniature turbojet engine?  Visit MMSOnline for a great video about this GE project.  Unfortunately, you’ll need Tony Stark’s Workshop Budget to be able to print one…
6 Comments
  • Well, although this is fascinating, I still enjoy the process of building balsa wood planes. Of course with superglues, I can build a plane a LOT faster than before. With a 3D printer, it’s not about building the model anymore. Its more about designing it on a computer.
    I think the hybrid approach is interesting for details like the pilot and cockpit. That would just be too rude to create in balsa!
    • Song, these 3D printed aircraft aren’t any differently really than the balsa aircraft. You’re taking die cut balsa parts and assembling them. These would be 3D printed plastic parts that need assembly. You’re not doing your own die cutting, and if you wanted to design a custom airplane to be made out of balsa, you could do so using the same tools you’d use to 3D print. You could even cut out the balsa at home with a laser cutter. Again the difference is that for a lot less money than a laser cutter, you could be 3D printing those parts.
  • I’ve been toying with the idea of getting a 3D printer for a while now and these planes have really encouraged me to what is possible with this tech. There are so many times that myself or other club members have broken a part on various flying machines and haven’t been able to replace them easily or not at all that makes having a printer a ideal solution to solve a lot of frustration and heartbreak.
  • I am looking for a pair of spinners, flying articles, for my P-38 1/2 A scale control line model. These are 1 3/4 ” diameter and could be attached to an aluminum back plate if necessary.
    No one has a correct shape spinner. I am going to compete at the Brodak contest in June.
    If you could make the spinners as good as the P-38 model, it would be fantastic! I really need these spinners- can you help?
    Thanks!
    Len Bechtold
    561 310-6125
  • Do the 3D printers simply take an STL file and printout the part?
    Is it easy to upscale and down scale STL files?
    What about print head resolution and the STL file?
    Is there a variation of G Code for 3D Printers?
    DesignCAD 3D Max ver 25 finally supports STL and OBJ files which I have been able to import and export from Blender, the Open Source and very powerful 3D Graphics program. I was about to abandon DesignCAD for its lack of STL support.
    Most of what I want to do right now can be done with 2D CAD and basic G-Code but am working to keep up with he 3D formats.
    Could you comment on CAD file formats and 3D surface resolution? I see that MeshCAM reads STL files.
    Which CAD programs are the hobbyists using to generate their STL files?
    I hope these are useful questions.
    Thank You.
  • This is a great article. Thank you for taking the time to put this together. I look forward to reading more of your posts!
