Chamfer Mill Speeds and Feeds [ Chamfering Tool Guide ]
The Chamfer Mill or Chamfering Tools are an essential part of any CNC’ers tooling.  They make it easy to put that nice chamfered edge on parts that is such a signature for CNC machined work.  This Easy Guide tells you every thing you’ll need to choose and use Chamfer Mills and Chamfering Tools.
What is a Fillet and a Chamfer?  What about a Bevel?
The easiest way to see the difference is with a picture of the different edge treatments:
whats the difference between a chamfer, fillet, and bevel?
What’s the difference between a Fillet, Chamfer, and Bevel?
Here are the different types of edge treatments:
  • A fillet is a radiused edge on the work piece.  The profile is an arc.
  • A chamfer applies a flat at an angle to the edge on the work piece.  The angle is usually a 45 degree chamfer.
  • A bevel occurs when the flat is the whole edge and there is no vertical wall.
Easy stuff, right?  But terminology matters so it’s important to lay it out.
What is the Purpose of Chamfers?
The most common reason to Chamfer Edges is to make sure they’re not sharp.  Machining operations can leave razor-sharp edges that can cut fingers and flesh.
Even if the edge is not too sharp, there may be burrs left behind by the machining process.  Cutting a chamfer removes the burrs and saves on other methods of Deburring.
Sharp Edges and Burrs are often unacceptable for finished parts.  Chamfer Mills can be an important part of deburring operations.  If a print specifies “break all edges”, chamfer the edges with a chamfer mill.
Another use for chamfers is to cause the head of a bolt to recess and be flat on a surface.
Chamfers are also more pleasing to the eye.  They make the edge less delicate and harder to damage.  If two pieces are to be welded together, put a chamfer along the welded joint for both pieces to support the welding process.
When Should You Choose a Fillet Instead of a Chamfer?
Fillets can be more expensive to cut.  They involve more material removal and the corner rounding bits used to cut fillets are more subject to chatter, so Feeds and Speed must be less.
So why would you ever choose to machine a Fillet over a Chamfer?
The biggest reason is stress distribution.  Chamfers do little to distribute stress whereas an arc for a Fillet is the ideal profile for stress distribution.  Also, if a protective coating such as paint will be applied, the thickness will be more uniform over a fillet than a chamfer.
One last tip–chamfers are more forgiving if parts must be fit together than are fillets.
Chamfering Tools, Chamfer Mills, Cutters, and Router Bits
The tools, bits or cutters used to Chamfer Edges go by the names “Chamfering Tools”, “Chamfer Tools”, “Chamfer Mills”, “Chamfer End Mills”, “Chamfer Cutters”, “Chamfer Bits”, or “Chamfer Router Bits” if you’re searching for them online.  We’ll just refer to them as “Chamfer Mills” from here on as they are a type of End Mill.
Typically, they look like this:
chamfering tools chamfer mills cutters router bits
Chamfer Mill…
Chamfer Mills Can Have Multiple Uses
In addition to creating chamfers, a chamfer mill can be used for multiple machining operations including beveling, deburring, countersinking, engraving, and spotting.
Taking advantage of the multiple uses can reduce tool changes and save time on your job.
Chamfered Holes and Spot Drills for Chamfering
Most holes and especially tapped holes benefit from a chamfer to clean up an burrs and ensure a clean start for threads.  Rather than using a conventional chamfer mill, holes are usually chamfered using a spot drill so the same tool can be used to spot the hole as well as to chamfer it.
Tip:  When using the same tool to spot and chamfer a hole, make sure the angle of the chamfer bit is larger than the angle of the drill that will follow it.
A calculator helps to determine the depth to spot given a desired chamfer and hole diameter:
Chamfer Depth Calculator
Our G-Wizard Feeds and Speeds Calculator includes a special geometry calculator that makes determining chamfer depth easy:
chamfer depth calculator
There’s even a handy database to tell you how deep to counterbore for fasteners:
chamfer counterbore fastener depth flat head screw
Try a Free 30-Day Trial of G-Wizard today.  Even if you don’t choose to purchase at the end of the trial, the chamfer calculator and fastener database will continue to work free of charge.
Chamfering Tool for Deburring
A chamfer mill is also a great deburring tool.  There are a lot of ways to deburr, but using a chamfer mill as a deburring tool is one of the most efficient because the process can be completely automated.  Manual deburring can be such a time consuming process, that it’s no wonder using a deburring tool in a CNC machine is so popular.
The whole edge of the chamfering tool is available when used as a deburring tool.  Only a very light depth of cut is needed, so higher feeds and speeds with long tool life are possible with deburring tools.
Combination Tools for Drilling and Chamfering
Combination tools save time by putting more than one function on the same tool.  This avoids a tool change to access two tools.  Whether you plan to interpolate a hole or drill it, you can get combination tools that have a countersink for chamfering on the same tool:
Combination_Cutting_Tool_Milling_Countersink
Combination single flute end mill and countersink…
00761182-002 DRIVEMATIC_0
Combination twist drill and countersink…
Of course it’s important that the hole depth requirements be compatible with the tool.  For example, a blind hole may not be deep enough to allow the combination countersink and twist drill to work.
Indexable Chamfer Mills
Like most other tooling categories, you can get indexable chamfer mills that use inserts that are cheaper to replace than buying an entire new solid chamfer mill.
Here’s a typical Indexable Chamfer Tool:
It’s a combination spot drill, chamfer mill, and engraving tool.  Talk about saving some tool changes!
Chamfers for Lathes
With Lathes, putting a chamfer on an edge is simple and doesn’t require special tooling.  It’s just part of the profile that needs to be cut.
Since the operation is so common, many CNC Lathes have a built-in capability to do chamfering and corner rounding (filleting) of edges.  It’s associated with the G01 command, and we discuss how to do that sort of programming in our Free Online CNC G-Code Programming Course.
Conversational Chamfering for Lathes with G-Wizard Editor
Our G-Wizard Editor software includes Conversational Programming, which makes it easy to chamfer the edges when a series of OD’s (Outer Diameters) are being cut:
ODTurnWizard
Note how the “Corner” column near the graphic has options to treat the corner with a Radius (Fillet), Chamfer, or leave it alone.
If you need even greater control, try the Conversational Chamfer Wizard:
Chamfer Conversational Programming CNC
Here’s a video demonstrating the Chamfer Wizard in action:
Chamfer Feeds and Speeds
It’s easy to figure Chamfer Mill Feeds and Speeds with G-Wizard Calculator:
Step 1:  Choose Machine and Material
As you would for any Feeds and Speeds calculation, setup your machine and material first.
Step 2: Choose the Right Tool
Chamfer Mills are a sub-type of Endmills.  So, click the tool selector, choose “Endmill” at top, set the material, coatings, and flutes, the choose “Chamfer/Countersink” from the Tip Shape menu.
Step 3: Use the Chamfer Depth Calculator or Fastener Database to find your Cut Depth and Cut Width
Suppose I’m cutting the chamfer on a 1/4″ Flat Head Cap Screw.  The Fastener Database says I need a counterbore depth of 0.161″, Chamfer Diameter of 0.280″ and an 82 degree angle counterbore:
Step 4:  Read Off Your Feeds and Speeds
From that information, G-Wizard gives me the Feeds and Speeds to use:
chamfer speeds and feeds
Pretty easy stuff, right?
5/5 - (7 votes)
Recently updated on February 29th, 2024 at 05:25 pm
