Aftercooling a Compressor to Cut Down on Moisture
Sep 6, 2011   //   by page.lysupportadmin   //   Blog, Projects, Techniques  //  No Comments
I hope you all had a good Labor Day weekend!
While corresponding with a machinist friend, I learned he was adding a transmission oil cooler to his compressor to help get rid of some of the moisture coming through the system. This is apparently a trick that’s been around for some time, and after doing a little research, it’s one I’d like to try on my own compressor.
First, a little bit of the theory. If you haven’t already noticed, compressors accumulate a ton of moisture. It’s a good idea to have an electric automatic drain in the bottom of your tank. The moisture comes because the air coming out of the compressor is pretty hot–a couple of hundred degrees isn’t unusual. It cools down when it enters the tank and tends to dump the moisture. If you’re using quite a bit of air, it may not have time to dump the moisture, which means it winds up in your air lines, your air tools, your paint sprayers, your CNC machinery, and well, you get the idea. Not good.
The aftercooler is just a simple cooler that goes between the compressor outlet and the tank. It’s goal is to cool the air before it gets to the tank, which causes it to drop a bunch of the moisture (not all, you still want a dryer or other moisture reducer if you need really dry air). There are both air-to-air and air-to-water aftercoolers. Heck, you can run a loop of copper pipe through a bucket of water and turn on the hose to run more water through the bucket and that works too. But, it sure is wasteful of the water.
The idea here is to plumb a transmission oil cooler in and let it do the cooling with a fan. You can either piggy back on the fan that cools the compressor or add another fan. Below are some photos from various shopmade aftercoolers:
Compressor aftercooler
Aftercooler system consisting of a B&M model 70266 (11″ x 8″ x 1½”) tranmission/engine oil cooler, an EBM Pabst model W2E250-HL06-01 230V AC fan (1160 cfm in open air) wired in parallell with the motor so when the motor runs, the fan runs and a Wilkerson model X01-04-M00 automatic drain. This fellow measured his compressor outlet temperature at 310F going into the aftercooler and 96F coming out. That’s a big drop! He says there are visible droplets of water in the plastic drain going to the Wilkerson. Note how he organized his plumbing to take the moisture down low and the air rising above.
Compressor with aftercooler
This fellow has made a number of improvements to his compressor, including an aftercooler with muffin fans on the backside…
Aftercooled compressor
Another compressor with a B&M transmission cooler and a 230V fan.
Guarded Aftercooler
Very professional looking guard on this aftercooler. The automatic drain is from below again…
Someday I’ll get an aftercooler on my projects list. Doesn’t look very hard to do and anything to keep more moisture out of the system has to be a good thing!
  1. I almost forgot: Shop Air!
     Business
     Products
     G-Wizard Calculator
          User Guide
          User Guide
     Gearotic Gear Software
     Troubleshooting
     User's Club
     Beginners: Soon!
     Software: Soon!
     Machining: Soon!
     CNC Tech: Soon!
     Idea Notebooks: Soon!
     Completed
     Simple Wish List
     Model Wish List
     Rash Ideas
CNC Machines
     Lathe: Soon!
     Mill: Soon!
     Router: Soon!
     3D Printer: Soon!
     Other Machines
No Thanks!
