Ballnose Surface Finishes
Sep 24, 2010   //   by Bob Warfield   //   Blog, Software, Techniques  //  No Comments
It’s a small world, I guess. No sooner did I get done adding a section to my Turner’s Cube page showcasing Widgitmaster’s lathe-turned versions when I find him asking a question on CNCZone about how to calculate stepover to achieve a desired finish when profiling with a ballnosed cutter. As it happens, this function is built into G-Wizard like so:
Ballnose information appears below the RPM and Feedrate when the “Ballnose Cutter” choice is checked. It provides the effective diameter based on depth of cut and for a given scallop height will tell you the RA/RMS Surface Finish and required stepover. In this case, to achieve a maximum scallop height of a tenth (0.0001″) for an RA finish of 100, we need a 0.011″ stepover. That’s about 2.2% of the tool’s diameter.
Feeds and speeds for ballnosed cutters can be a bit tricky because the effective diameter of the tool is based on the cutting depth whenever you’re less than have the diameter of the tool deep. Think about it, the end of the cutter is a ball rather than the usual cylinder shape. You have to calculate the effective diameter based on how far the ball is into the workpiece.
  1. Interpolating Holes vs Twist Drills
     Business
     Products
     G-Wizard Calculator
          User Guide
          User Guide
     Gearotic Gear Software
     Troubleshooting
     User's Club
     Beginners: Soon!
     Software: Soon!
     Machining: Soon!
     CNC Tech: Soon!
     Idea Notebooks: Soon!
     Completed
     Simple Wish List
     Model Wish List
     Rash Ideas
CNC Machines
     Lathe: Soon!
     Mill: Soon!
     Router: Soon!
     3D Printer: Soon!
     Other Machines
No Thanks!
